PROBLEM
The Cut command is not enabled for graphics or map elements
The Cut command, available from the Edit menu or an element’s context menu, is not enabled when working with graphics and map elements. The shortcut Ctrl+X doesn't work either.
Cause
The Cut command is only enabled while editing features.
Solution or Workaround
When working with graphics or map elements, use Copy and Delete instead.
Article ID:000003603
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
