English
Problem: ArcSDE 8.1 Java API: Can't retrieve date values from an ArcSDE for Coverages server
Incorrect values are returned when retrieving date values from an ArcSDE for Coverages server. When using the SeQuery class, of the Java application programming interface (API), and methods to fetch values of date data types, the value of the date returned is different from the actual value stored in the server.
Cause
This is a known limit of the ArcSDE Java API.
Solution or Workaround
This problem is addressed in ArcGIS 8.1 Service Pack 1 and later releases of ArcSDE. Click on the link in Related Information, below; click on ArcSDE and under version 8.1, select ArcGIS Service Pack 1. Follow download instructions.
    Related Information
