English
Error: Dynamic link library UTQE32.DLL - The application failed to initialize properly (0xC0000135)
Error Message
When using SQL connectivity on a dual boot Windows/Windows NT machine, these error messages occur:
"The dynamic link library UTQE32.DLL could not be found in the specified path C:\..."
"The application failed to initialize properly (0xC0000135). Click OK to terminate the application."
Cause
SQL connectivity is installed on only one platform, and ArcView will not boot on the
platform without SQL.
Solution or Workaround
Install SQL connectivity on both platforms. This will ensure the appropriate ODBC files for both Windows and Windows NT are available on the machine.
