English
Problem: The Attribute Inspector doesn't recognize changes to a layers Primary Display field
After applying changes to the Primary Display field, from the layers property sheet, the Attributes dialog box will not recognize those changes.
Cause
Changes to the Primary Display field are not recognized within an edit session.
Solution or Workaround
To see the new primary display field, stop the edit session and start editing.
