PROBLEM
Cannot interact with the tools when more than one Convert to Geodatabase tool is open
When more than one Import to Geodatabase tool is opened at a time, the tools will begin to flicker. It is impossible to interact with either one of the tools. This occurs immediately after closing the Ouput Settings dialog box.
Cause
This is a known issue.
Solution or Workaround
Do not open more than one Import to Geodatabase tool at a time.
Article ID:000003552
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
