English
Problem: Geocoded points are placed beyond the extent of the reference theme
The features of a geocoded point theme appear in a perfect circle or another shape beyond the reference theme's extent.
Cause
You specified an offset distance on the Geocoding Addresses dialog box but didn't set distance units for the view.
Solution or Workaround
Set appropriate map units and distance units.
