English
How To: Reclassify grid themes using Avenue
Summary
The Spatial Analyst extension allows you to change grid cells values using the Reclassify Values dialog box. There may be instances when your application requires you accomplish this task using Avenue. The examples in this article show you how to do this by applying the Reclass, ReclassByClassList, SetNull, or Con requests to the grid Avenue class.
Procedure
You may modify these examples to suit your needs.
  • Reclassify one value or range of values to another using the Reclass request. For example, change cell values between 50 and 100 to 150.
    Code:
    theView = av.getactivedoc
    theTheme = theView.Getactivethemes.Get(0)
    inGrid = theTheme.GetGrid
    '-- Get input and output values from the user
    chgList = MsgBox.MultiInput
    ("Enter range values",
    "Reclassify cells",
    {"Input "+"from".quote+" cell value", "Input "+"to".quote+" cell value","Change to this output cell value"},
    If (chgList.count = 0) then
    exit
    End
    chgFrom1 = chgList.Get(0)
    chgFrom2 = chgList.Get(1)
    chgTo = chgList.Get(2)
    if (chgFrom1.IsNumber and chgTo.IsNumber) then
    '-- Make a new VTab to hold the to and from reclass values
    outname = av.GetProject.GetWorkDir.MakeTmp("rec", "dbf")
    recVtab = VTab.MakeNew(outname,dBASE)
    frmField = Field.Make("frmFld",#field_short,10,0)
    toField = Field.Make("toFld",#field_short,10,0)
    outField = Field.Make("outFld",#field_short,10,0)
    recVtab.AddFields({frmField,toField,outField})
    recnum = recVtab.AddRecord
    '-- Populate the VTab with the to and from reclass values
    recVtab.SetValue(frmField,recnum,chgFrom1.AsNumber)
    recVtab.SetValue(toField, recnum,chgFrom2.AsNumber)
    recVtab.SetValue(outField,recnum,chgTo.AsNumber)
    While (TRUE)
    again = MsgBox.YesNo("Would you like to add another value?","Reclass",TRUE)
    if (not again) then
    break
    else
    chgList = MsgBox.MultiInput ("Enter range values", "Reclassify cells",
    end
    end
    '-- Reclassify the input Grid. Make a new output Grid
    r = inGrid.Reclass(recVtab,frmField,toField,outField,false)
    '-- Set name of data set
    reclassFN = av.GetProject.GetWorkDir.MakeTmp("rctemp", "")
    r.Rename(reclassFN)
    '-- Check if output is OK
    if (r.HasError) then
    msgbox.info("r.HasError","")
    return NIL end
    '-- Create a theme (after renaming data set)
    gthm = GTheme.Make(r)
    '-- Set name for theme
    gthm.SetName("Reclass of " + theTheme.GetName)
    '-- Add theme to the View
    theView.AddTheme(gthm)
    recVTab.DeActivate
    File.Delete(outname)
    end
  • Reclassify one value to another using the Con request. For example, change cell values of 187 to 253.
    Code:
    ("Enter value to change",
    "Reclassify cells",
    {"Input "+"from".quote+" cell value","Change to this output cell value"},
    If (chgList.Count = 0) then
    exit
    End
    chgFrom = chgList.Get(0)
    chgTo = chgList.Get(1)
    if (chgFrom.IsNumber and chgTo.IsNumber)
    then
    r = (inGrid = chgFrom.AsNumber).Con(chgTo.AsNumber.AsGrid,inGrid)
    msgbox.info("Output Grid has an error","")
    return NIL end
    end
  • Reclassify from a real value to NODATA, using the SetNull request. For example, change cell values of 98 to NODATA.
    Code:
    chgFrom = MsgBox.Input("Enter cell number value", "Reclassify cells to NO DATA","")
    If (chgFrom = nil) then
    exit
    End
    if (chgFrom.IsNumber)
    then
    r = (inGrid = chgFrom.AsNumber.AsGrid).SetNull(inGrid)
    '-- Check if output is ok
    return NIL end
    end
  • Reclassify from NODATA to a real value, using the Con request. For example, change NODATA cell to a cell values of 678.
    Code:
    chgTo = MsgBox.Input("Enter cell number value", "Reclassify NO DATA cells to a number","")
    If (chgTo = nil) then
    exit
    End
    if (chgTo.IsNumber)
    then
    r= (inGrid.IsNull).Con(chgTo.AsNumber.AsGrid,inGrid)
    return NIL end
    end
