English
How To: Create a histogram from attribute values in ArcMap
Summary
You can use the Selection Statistics tool to create a histogram for a field within a selected group of features. You can also easily compare histograms between several fields with this tool.
Procedure
  1. Select Features using any method.
  2. Click Selection > Statistics.
  3. Select a Layer and Field. The Selection Statistics dialog box will show the desired bar graph.
    You cannot save, print, customize the properties, or create this histogram from stand-alone tables.
