English
Error: When adding a TIFF image to a project as an Image Analysis theme 'Unable to Find Layers in Image' is returned
Error Message
ArcView returns this error when adding a TIFF image to a project as an Image Analysis theme:
"Unable to Find Layers in Image"
Cause
The TIFF image uses either CCITT or packed bits compression method, which are not supported by Image Analysis.
Solution or Workaround
Use an image processing software, such as Windows NT Imaging, Paint Shop Pro, PhotoShop, and so forth, to save the image as an uncompressed TIFF.
