English
Problem: Cannot open the default.apr
The project default.apr in the $AVHOME/etc or $HOME directories will not open.
Cause
The default.apr is not a regular project file that can be opened as a project within ArcView. This is a special file used by ArcView only on startup.
Solution or Workaround
Don't attempt to open this file as a project.
