ERROR
When importing an .e00 file, ArcView returns an Error -43.
Error -43 indicates that a file or folder cannot be found.
Move the interchange files to the local hard drive and try the import process again. If the Import process still fails, place the .e00 files in the ArcView application folder. You may also try shortening the file names.
Get help from ArcGIS experts
Download the Esri Support App
