PROBLEM
Lowering the spelling sensitivity for a geocoding service produces additional candidates for addresses with the same street name
When finding candidates for an address, either in the Find dialog box in ArcMap, or in the Interactive Review dialog box, lowering the geocoding service's spelling sensitivity setting can generate additional candidates for the address that have the same street name as the address.
Cause
This is a known issue.
Solution or Workaround
Set the spelling sensitivity for the geocoding service to a lower value in order to reduce the occurrences of this problem.
Article ID:000003509
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
