English
Problem: INFODBASE and ARCSHAPE add a null character to the end of text fields in the output files
This problem is addressed in ArcGIS 8.1 Service Pack 1. See Related Information section below.
The INFODBASE and ARCSHAPE commands are adding a null character at the end of each value in text fields. This shows up as a box in Excel, and as a vertical line in Foxpro . For example:
OID TXTFIELD
101 Blue|
102 Green|
Cause
This is a known issue at version 8.1.
Solution or Workaround
The following two methods have multiple options for removing the null characters or avoiding them when converting a coverage to a shapfile.
  • Remove the null characters from the output dBase file:
    1. Manually remove the null characters from all output text fields.
    2. In Access, import the dBASE table, then export it back.
    3. In Excel, use the following formula in a new column:
      =left, B1,((len(B1)-1)
      Where B is the text column which contains the null values.
  • Avoid the creation of the null characters when exporting a coverage to a shapefile:
    1. Use the LAYERDEFINE and LAYEREXPORT commands in ArcInfo Workstation to export the coverage to a shapefile.
    2. Use the Coverage to Shapefile tool in ArcCatalog or ArcToolbox. These tools execute the LAYERDEFINE and LAYEREXPORT commands.
Related Information
