English
Problem: JRun 3.0 sp2 service fails to start
JRun 3.0 sp2 service fails to start automatically upon system login after logout.
Cause
This is a known issue with JDK 1.3.
Solution or Workaround
  1. Open the global.properties file located at
    <drive>:\Program Files\Allaire\JRun\lib
  2. Set java.exe to {jrun.rootdir}/bin/dontdiejava.exe
  3. Add an extra entry for java.jnipath:
    <drive>:\\jdk1.3\\jre\\bin\\hotspot
  4. Save the file.
