English
Error: Method or data member not found
Error Message
Running ArcObjects code returns the following error:
"Method or data member not found."
Cause
The Set keyword is used incorrectly. Set is required to assign a property by reference and to create new objects. Set is not required when setting a property by value.
Solution or Workaround
Follow these guidelines when deciding whether or not to use Set in your code:
  • Use Set to assign a property by reference.
    Code:
    Set pPageLayout = pMxDoc.PageLayout
  • Set is not necessary when a property is assigned by value.
    Code:
    pMap.MapUnits = esriFeet
  • Set is required when creating new objects.
    Code:
    Dim pFeature as IFeature
    Set pFeature = New Feature
    For more information on Set see the book 'Exploring ArcObjects'.
