English
Error: One or more layers failed to draw: General function failure
Error Message
Attempting to display flow arrows on a geometric network in ArcMap returns:
Code:
General function failure [EdgeFeatureClassName]
Syntax error (comma) in query expression 'SHAPE_Length >= 123,56789'
Cause
This problem only occurs when the decimal symbol in the Regional Settings is not a '.', which is common on most European computers. When the decimal symbol is not a '.', then the query expression fails with a syntax error.
Solution or Workaround
This problem is addressed in ArcGIS 8.1 Service Pack 1. See the Related Information section to download this pack.
    Related Information
