In my Java Viewer, my map display is off-center and I cannot access restricted MapServices
In my Java Viewer, my map display is off-center and I cannot access restricted MapServices.
Cause
You have JRE 1.3-C.
Solution or Workaround
Upgrade to the international version of JRE 1.3.0_02. Click the link below to go to the Sun web site. MAKE SURE YOU DOWNLOAD THE INTERNATIONAL VERSION OF JRE 1.3.0_02.
