English
FAQ: Are there any issues with geocoding on a versioned feature class using ArcSDE for DB2?
Question
Answer
There is an issue with geocoding on a versioned dataset. After loading some data, register it as multiversioned. Create a geocoding service on this feature class. Now try to locate the address in ArcMap using this geocoding service and find an address. If the feature class is not registered as versioned, then it finds the address; but if it's versioned, then ArcMap just sits there and nothing happens.
To geocode against this feature class you must:
1. Unregister the feature class as versioned.
2. Re-create the geocoding service.
