PROBLEM
Creating a spatial join on a layer that contains route events creates the wrong results
This problem is addressed in ArcGIS 8.1 Service Pack 1. See Related Information section to download this pack.
Creating a spatial join using a layer that is based on route events causes incorrect results.
Cause
This is a known limitation for layers containing route events.
Solution or Workaround
  1. Export the layer to a shapefile or geodatabase feature class stored on disk.
  2. Create the spatial join using the new feature class.
Article ID:000003410
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
