English
How To: Check whether a feature class can store measure or M values
Summary
In order to store measure or M values, the geometry definition of a feature class must have the HasM property set to True (IGeometryDef::HasM = True). For shapefiles and geodatabase feature classes, you can check this property in ArcCatalog.
Procedure
  1. In ArcCatalog, right-click a feature class and select Properties.
  2. On the Fields tab, left-click the SHAPE field.
  3. If the ‘Contains M values’ property is Yes, then the feature class can store M values.
    Once created, the geometry definition of a feature class cannot be changed. If the ‘Contains M values’ property of a feature class is No, then you will have to reload the data into a new feature class. When reloading data into a new Geodatabase feature class, you can enable M values in the output by selecting the Geometry tab and checking the 'Enable M values on the output' box.
    If you are creating a new shapefile, you will have to write code to enable measure values in the output.
