HOW TO
Use fonts in Maplex
Summary
This article provides information on Maplex fonts.
Procedure
The Font Modifier file (fmod9.dat) is the primary source for Maplex font information.
This file is created the first time the Map:Fonts:Add Fonts button is pressed. Once the file is created there is a choice of where the font information can be accessed from.
  • PostScript fonts
    [O-Image] Maplex Add Postscript Fonts menu
  • ArcInfo fonts: Set the ArcHome folder in the Add Fonts menu.
    [O-Image] Maplex Add Fonts menu
    The fontindex file is located in <drive>:\arcexeXX\locale\c. Fonts are usually in the <drive>:\arcexeXX\fonts folder but could be anywhere on the system; the path is stored in the fontindex file for each font that is referenced.
  • Windows fonts: These are installed on the system and are located in c:\winnt\fonts directory.
Article ID:000003404
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
