Summary
The Zoom to Layer command, in the Table of Contents feature layer context menu, does not zoom to the extent of the events in a layer based on route events. The Zoom to Layer command zooms to the extent of the route feature class upon which the events are based.
Procedure
- Create a UIButtonControl.
For information on creating a UIControl see the ArcGIS Desktop Help topic 'How to create custom commands with VBA'.
- Right-click the UIButtonControl and select View Source.
- Paste the code into the UIButtonClick event.
Sub ZoomToSelectedLayer()
Dim pMxDoc As IMxDocument
Dim pMap As IMap
Dim pActiveView As IActiveView
Dim pContentsView As IContentsView
Dim pLayer As ILayer
Dim pFLayer As IFeatureLayer
Dim pFC As IFeatureClass
Dim pEnv As IEnvelope
Dim pMapSR As ISpatialReference
Set pMxDoc = Application.Document
Set pMap = pMxDoc.FocusMap
Set pMapSR = pMap.SpatialReference
Set pActiveView = pMap
Set pContentsView = pMxDoc.CurrentContentsView
If TypeOf pContentsView.SelectedItem Is ILayer Then
Set pLayer = pContentsView.SelectedItem
If TypeOf pLayer Is IFeatureLayer Then
Set pFLayer = pLayer
Set pFC = pFLayer.FeatureClass
If TypeOf pFC Is IRouteEventSource Then
Dim pGC As IGeometryCollection
Dim pFCur As IFeatureCursor
Dim pFeat As IFeature
Dim pGeom As IGeometry
Dim pSR As ISpatialReference
Dim pRES As IRouteEventSource
Dim pRtLoc As IRouteLocator
Set pRES = pFC
Set pRtLoc = pRES.RouteLocator
Set pSR = pRtLoc.SpatialReference
Set pFCur = pFC.Search(Nothing, False)
Set pGC = New GeometryBag
Set pFeat = pFCur.NextFeature
While Not pFeat Is Nothing
pGC.AddGeometry pFeat.ShapeCopy
Wend
Set pGeom = pGC
Set pGeom.SpatialReference = pSR
pGeom.Project pMapSR 'project to map's spatial reference
Set pEnv = pGeom.Envelope
Else
Set pEnv = pLayer.AreaOfInterest 'spatial reference envelope
End If
Else
End If
If Not pEnv Is Nothing Then
If Not pEnv.IsEmpty Then
pEnv.Expand 1.05, 1.05, True '+++ add 5% to the envelope
pActiveView.Extent = pEnv
pActiveView.Refresh
End If
End If
End If
End Sub
- Highlight the layer you wish to zoom to in the Table of Contents.
- Click the button you added in step 1.
