PROBLEM
Empty Display Hardware Key Status
When running User Diagnostics in ArcGIS 8.1, the portion allocated for Display Hardware Key Status is blank.
Solution or Workaround
Verify the status of the key with other available methods.
  • Click Start > Programs > ArcGIS > License Manager > Display Hardware Key Status.
  • Open a Command Prompt window.
    A. Click Start > Run > type cmd.
    B. Click OK.
  • Type the following:
    Code:
    C:\>cd Program Files\ESRI\License
    C:\Program Files\ESRI\License> esrihostid.exe
Article ID:000003400
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
