PROBLEM
The Find tool can be used to find a Route Location. Sometimes when trying to zoom to a route location, the new extent is not centered on the found location.
This is a known limitation for route locations that fall on a perfectly straight vertical or horizontal portion of a route.
There is no workaround for this limitation.
Get help from ArcGIS experts
Download the Esri Support App
