PROBLEM
Shading may become inverted for a raster layer in ArcScene
Typing a negative Z unit conversion factor on the Base Heights tab for a raster, when its base surface is also a raster, results in an image whose top looks dark and the underside is light. The top should be light.
Cause
This is a known issue.
Solution or Workaround
ArcObjects Online contains a developer sample that can be used to factor the base raster surface.
  1. Click the link below and expand Samples > 3D Analyst > Surface Analysis.
  2. Download the Raster Math Command sample. You can use this sample to multiply a raster by any value.
Article ID:000003374
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
