PROBLEM
Adjusting print quality in ArcScene has no effect
When printing form ArcScene, you cannot adjust the output image quality from the page setup dialog.
Cause
This is a known issue.
Solution or Workaround
  1. Use the Export > 2D option under the file menu.
  2. Specify the desired resolution of the output image using the 'Scene size' option.
  3. Place resulting image in ArcMap or other publishing application for high-quality printing.
Article ID:000003366
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
