Frequently asked question
How do I specify a null value for fields with coded value domains in the Attribute Inspector?
Answer
Fields that have coded value domains associated with them are displayed in the Attribute Inspector as a dropdown list of valid values. Fields that allow null values, will contain a <Null> entry in that dropdown list. To set the field's value to null, select the <Null> entry from the dropdown domain value list.
Article ID:000003358
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
