PROBLEM
Create TIN dialog default output location might incorrectly point inside an ArcInfo coverage
If the last browse location for getting or saving data in ArcScene, or ArcMap, was a coverage, the Create TIN From Features dialog box will provide a default output TIN location that is inside the coverage folder.
Cause
This is a known issue.
Solution or Workaround
Check the default output path of the dialog to ensure it is an appropriate location for the resulting TIN.
Article ID:000003351
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
