PROBLEM
Some temporary files are not being removed after some Spatial Analyst functions complete processing.
This is a known issue with ArcGIS 8.1.
The following files will not be removed:
· The INFO file generated by the Zonal Statistics function.
· The scratch table generated by the Histogram tool.
· Temporary shapefiles that get created when performing certain tasks, such as during projection, format conversion, or selection.
A regular cleanup of your working directory will alleviate this problem. Always remove ESRI grids with ArcCatalog or ArcInfo Workstation in order to remove the associated INFO files.
Get help from ArcGIS experts
Download the Esri Support App
