PROBLEM
Default working directory for Spatial Analyst cannot be found on Windows 2000
The default working directory for Spatial Analyst cannot be found by navigating to its location in a file browser on a Windows 2000 machine.
Cause
The default working directory for Spatial Analyst on Windows 2000 is a hidden folder. It is stored under C:\Documents and Settings\<username>\Local Settings\Temp.
Solution or Workaround
To see this hidden folder with a Windows file browser, click Tools > Folder Options, then click the View tab and check Show hidden files and folders.
Article ID:000003324
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
