PROBLEM
ArcMap will not recognize a newly added raster format Dynamically Linked Library (DLL)
Last Published: April 26, 2020
After creating a raster format DLL, to view and use a raster format not currently supported by ArcGIS, the raster is not listed in ArcMap or ArcCatalog.
Cause
The Windows registry keys do not detect the new format DLL.
Solution or Workaround
Warning:
The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary.
Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
  1. Use RegEdit to delete all values under the key HKEY_CURRENT_USER\Software\ESRI\Raster.
  2. Navigate tot the following folder:
    C:\ArcGIS\ArcEXE81\Raster\Devices\NTx86\Win32_NT
    Delete the following files:
    • RasterFormats.cfg
    • GeometricModels.cfg
    • ResampleMethods.cfg
Article ID:000003292
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
