English
Error: Error Exporting Data
Error Message
When you create a selection set of CAD features in ArcMap, and attempt to export them using the Export Data command, the selected CAD features will not export. The following messages will occur:
"Error Exporting Data"
"Warning: Some records may not have been exported correctly"
"There was an error exporting the layer"
Cause
This is a known issue.
Solution or Workaround
  1. Export the entire CAD feature class to a shapefile or geodatabase feature class.
  2. Create a selection set using the newly created shapefile or geodatabase feature class.
  3. Re-export the selected features to a new shapefile or geodatabase feature class.
Related Information
