PROBLEM
ArcGIS displays text from CAD drawings differently than the original CAD software
The font, size, and extent of CAD drawing text is different in ArcMap than what the original CAD drawing software displays.
Cause
ArcGIS uses the operating system's default font when displaying CAD drawing text. Specific display settings saved by the original CAD software package are not used.
Solution or Workaround
Use CAD annotation feature classes in ArcGIS to customize the appearance of CAD text. You can change the font, color, and style of CAD annotation features in the Fonts panel of the Layer Properties sheet. In some cases you may also need to obtain the TrueType version of a CAD font that was used in the original drawing in order to recreate the appearance.
Article ID:000003285
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
