BUG
After setting the edge-edge rule, setting the default junction in edge-junction rule is not persisted
**This issue has been resolved in ArcGIS (Desktop, Engine, Server) 9.3.1 Service Pack 2.**
The junction is not set as the default for the edge-junction rule after the following actions have been taken:
1. Establish an edge-edge connectivity rule.
2. Set the junction as the default for the edge-junction rule that was implicitly created when the edge-edge rule was established.
3. Click OK.
4. Re-open the Geometric Network Properties dialog box.
Workaround
  1. Click 'Apply' after setting the edge-edge connectivity rule.
  2. Right-click the junction class in the 'Subtypes in the Network' tree view to set it as the default.
    [O-Image] ConnRules_EdgeJunction
  3. Click 'Apply'.
  4. Click 'OK' to dismiss the dialog box.
    The junction is set as the default for the specific edge-junction connectivity rule.
Article ID:000003266
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
