English
FAQ: SQL Server: Why does ArcMap crash when opening the attribute table of a large feature class when all features are selected?
Question
Answer
If you open the attribute table of a large feature class when all features are selected the gsrvr process may crash.
This occurs with SQL Server 7.0 feature classes with more than 500,000 features. The problem does not occur in SQL Server 2000.
As a workaround install MDAC 2.6 or use SQL Server 2000.
