PROBLEM
The VISIBILITY function is not respecting the SETCELL or SETWINDOW settings
The VISIBILITY() function in GRID doesn't respect the SETCELL or SETWINDOW settings.
Cause
This is a known software limitation.
Solution or Workaround
These are two methods to make an output grid with the desired resolution:
  • Method 1: Run the SETWINDOW command to specify the correct extent, and then use the RESAMPLE() function on the result from VISIBILITY().
  • Method 2: Clip and resample the grid before performing VISIBILITY().
Article ID:000003255
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
