English
How To: Improve performance when geocoding a table against a large reference geocoding index
Summary
SQL Server: You can dramatically improve geocoding performance by creating a clustered covering index on the SX,XID columns of the geocoding index table.
Procedure
Execute the Transact-Sql CREATE INDEX command against your geocoding index table. Identify your geocoding index table by running the sdelocator command with the -o describe option. For example:
Code:
sdelocator -o describe -n citystreets -i 9000 -u geocode -p find_address -D idb
This command will return a long list. At the bottom, locate a string similar to this:
Code:
RD.Val.IdxTable1 = idb.DBO.GC_SS582
Use this table in your CREATE INDEX statement:
Code:
Create clustered index idxGC_Cov on dbo.GC_SS582(SX,XID)
You can also create an index with the Enterprise Manager.
