English
Problem: Output from the STREAMLINK function has a larger file size than expected
The output grid from the STREAMLINK function is larger than it should, given the number of rows and columns.
Cause
The grid compression scheme within this function is not being correctly applied. This is a known issue.
Solution or Workaround
This issue has been addressed in ArcGIS Version 8.1.2
In ArcGIS 8.1, you can use the INT() function to create a new grid with the compression correctly implemented. Running the INT() function does not affect the contents of the data because the result from STREAMLINK() is already an integer grid.
  1. Generate the streamlink grid.
    Code:
    Grid: out_grid1 = streamlink (net_grid, dir_grid)
  2. Run the INT() function.
    Code:
    Grid: out_grid2 = int (out_grid1)
  3. Delete the original streamlink grid.
    Code:
    Grid: kill out_grid1
