When rotating the contents of a data frame, the graticule disappears. The data frame is using a geographic coordinate system.
Solution or Workaround
Instead of using a geographic coordinate system, set your data frame to use the Plate Carree projected coordinate system.
- Open the Data Frame Properties dialog box and select the Coordinate System tab.
- Select Predefined > Projected Coordinate Systems > World > Plate Carree (world) from the list of coordinate systems.
- Click OK to close the Data Frame Properties dialog box.
- Rotate the data frame to the desired angle using the rotation tools on the Data Frame Tools toolbar.
