English
Problem: Extension options are grayed out
When opening an extension toolbar such as Spatial Analyst or Publisher, everything is grayed out.
Cause
The extension has not been activated.
Solution or Workaround
  1. Start ArcMap or ArcCatalog.
  2. Select Tools > Extensions.
  3. Check the box next to the desired extension.
  4. Click Close.
Related Information
