PROBLEM
After installing ArcInfo 8.0.2 Patch 1, ArcEdit and ArcPlot will not start and the following error message is returned:
"Procedure entry point disable_rqu could not be located in the dynamic link library aifeat.dll"
Patch 1 installs the aifeat.dll in the directory arcexe80\lib. The above error message is returned if an earlier version of the aifeat.dll is in the arcexe80\bin directory.
Warning: The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary. Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
Get help from ArcGIS experts
Download the Esri Support App
