English
Error: Failed to rename selected object(s)
Error Message
When attempting to rename a data set in ArcCatalog, this error occurs:
"Failed to rename selected object(s)."
Cause
This error may occur under one of the following situations:
• The data may have read-only permissions.
• The data is open in ArcMap.
Solution or Workaround
Use your operating system to check and change the file's permissions.
The Rename menu option is always enabled as permissions are only checked when actually executing the command. This was designed to improve the overall performance of ArcCatalog.
