English
Problem: The Simple Data Loader and Object Loader prompt for the username and password several times
When using the ArcSDE geodatabase feature class as a source where the connection file does not include the name and password, the Simple Data Loader and Object Loader prompt for the username and password several times.
Cause
The Load Data tool doesn't cache the connection information.
Solution or Workaround
Create a new connection to the ArcSDE geodatabase in ArcCatalog and save the username and password with the connection.
