English
Problem: Can't access Help or Geography Network using ArcExplorer or ArcIMS shortcuts
Using the ArcExplorer-Java shortcut on Windows, a user receives an error when trying to access Help or the Geography Network.
This is also a problem with the ArcIMS shortcut.
Cause
The ArcExplorer-Java edition properties file, aimsclient.properties, gets installed to the install person's home directory (usually C:\Winnt\profiles\user_name). But the shortcut to start ArcExplorer-Java edition is created under ALL Users. So, if the user who did the install logs out, and another user logs in and tries the ArcExplorer-Java shortcut, the user will receive an error when trying to access Help or the Geography Network.
With ArcIMS and the associated properties files that are in the HOME directory, the shortcuts are created for ALL USERS, so the new user thinks it's accessible, but will get an error if aimsdefault.properties isn't in the HOME directory.
Solution or Workaround
The solution is to copy aimsclient.properties (ArcExplorer-Java edition) and/or aimsdefault.properties (ArcIMS) to the HOME directory.
