ERROR
Using Raster::SaveAs returns 'Automation error'
Error Message
In a customized environment, the Raster::SaveAs method returns an automation error when the output workspace is an SDE workspace.
Cause
This is a known issue. A raster cannot be saved to a geodatabase using Raster::SaveAs with ArcGIS 8.1.
Solution or Workaround
Use the RasterDataset::SaveAs method to save the raster dataset to a geodatabase.
Article ID:000003177
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
