English
Problem: Display windows with &fullscreen &popup on OpenWindows are not entirely within the viewing area
With ArcInfo 8.1 on OpenWindows, display windows created with the &fullscreen &popup command are not entirely within the viewing area.
Cause
A conflict exists because ArcInfo 8.1 uses newer Motif 2.1 libraries and OpenWindows is using version 1.2 libraries.
Solution or Workaround
Drag the popup window back into your viewing area or use the CDE environment instead of OpenWindows.
Related Information
