PROBLEM
Slow preview display in ArcMap or ArcCatalog of rasters stored in a geodatabase
In ArcGIS, previewing a raster dataset stored in a geodatabase takes longer than when the raster is in a file system.
Cause
There are three likely causes for this problem:
· The raster is stored in the geodatabase without pyramid layers. Each time the client submits a query, the server has to look up the whole extent to find the correct tiles; this can be a slow process.
· The network connection is slow.
· If using an Oracle database, the tables may not have been properly analyzed. The Oracle optimizer will subsequently take longer to locate the records in the block table.
Solution or Workaround
These are the respective solutions for the above causes.
  • The raster is stored in the geodatabase without pyramid layers: Select the Build Pyramids option when loading the raster into the geodatabase.
  • The network connection is slow: Increase the network connection speed by optimizing the server or upgrading the network hardware.
  • Using an Oracle database: Always analyze the raster tables after loading into the Oracle database.
Article ID:000003174
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
