English
Problem: Operation Failed [loading raster]
Attempting to load a raster with a data depth of two bits fails with this error message:
“Operation Failed”
Cause
This is a known issue.
Solution or Workaround
  1. Write a script to save the raster dataset to another data type, such as 4-bit, using Raster::SaveAs.
  2. Load the resulting output raster dataset into the database.
Related Information
