Frequently asked question
Can rasters be copied from one geodatabase into another?
Answer
Yes, once you have loaded a raster into a geodatabase, you can copy it into other geodatabases using the Export Raster To Different Format option. Keep in mind that you cannot export raster data to the same connection, but you can copy rasters between two different database instances.
Article ID:000003148
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
