English
Problem: Merge policies are not enforced
Attribute values are not updated based on the field's domain merge policy.
Cause
A special merge tool is required to enforce merge policies.
Solution or Workaround
Use the ArcGIS Developer Online sample called "Merge features and respect merge rules". Please see the link in the related information section. Once at the Web site, select Samples > Geodatabase > Schema Creation and Management > Merge features and respect rules. Follow the instructions provided to download and use the tool.
Related Information
